В панели задач при перезапуске исчезала панель быстрого запуска (На ноутбуке с Win XP Home) и отображались не все значки уведомлений, которые нужны.(Справа внизу возле часов). Удалось исправить следующим скриптом:
Просто я создал блокнот, занёс туда это:
Set WSHShell = WScript.CreateObject("WScript.Shell")
Message = "To work correctly, the sсriрt will close" & vbCR
Message = Message & "and restart the Windows Explorer shell." & vbCR
Message = Message & "This will not harm your system." & vbCR & vbCR
Message = Message & "Continue?"
X = MsgBox(Message, vbYesNo, "Notice")
If X = 6 Then
On Error Resume Next
WshShell.RegDelete "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StuckRects2\"
WshShell.RegDelete "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU\"
WshShell.RegDelete "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Streams\Desktop\"
WshShell.RegDelete "HKCU\Software\Microsoft\Internet Explorer\Explorer Bars\{32683183-48a0-441b-a342-7c2a440a9478}\BarSize"
P1 = "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\"
WshShell.RegWrite p1 & "NoBandCustomize", 0, "REG_DWORD"
WshShell.RegWrite p1 & "NoMovingBands", 0, "REG_DWORD"
WshShell.RegWrite p1 & "NoCloseDragDropBands", 0, "REG_DWORD"
WshShell.RegWrite p1 & "NoSetTaskbar", 0, "REG_DWORD"
WshShell.RegWrite p1 & "NoToolbarsOnTaskbar", 0, "REG_DWORD"
WshShell.RegWrite p1 & "NoSaveSettings",0,"REG_DWORD"
WshShell.RegWrite p1 & "NoSetTaskbar",0,"REG_DWORD"
WshShell.RegWrite p1 & "NoActiveDesktop",0,"REG_DWORD"
WshShell.RegWrite p1 & "ClassicShell",0,"REG_DWORD"
p1 = "HKCU\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\"
WshShell.RegDelete p1 & "NoMovingBands"
p1 = "HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Shell"
WshShell.RegWrite p1, "explorer.exe", "REG_SZ"
p1 = "HKCU\Software\Microsoft\Internet Explorer\Explorer Bars\{32683183-48a0-441b-a342-7c2a440a9478}\"
WshShell.RegDelete p1 & "BarSize"
WshShell.RegWrite p1, "Media Band", "REG_SZ"
On Error Goto 0
For Each Process in GetObject("winmgmts:"). _
ExecQuery ("select * from Win32_Process where name='explorer.exe'")
Process.terminate(0)
Next
MsgBox "Finished." & vbcr & vbcr & "c Kelly Theriot and Doug Knox", 4096, "Done"
Else
MsgBox "No changes were made to your system." & vbcr & vbcr & "c Kelly Theriot and Doug Knox", 4096, "User Cancelled"
End If
Потом сохранил файл как 1.vbs Потом запустил полученный файл и всё встало на свои места. Даная команда меняет панель задач "по умолчанию". Может кому-нибудь и пригодится. |
Раньше часто подобное было, когда винда уже долго стоит. Значки пропадали с панели задач и всё, хз как вернуть.
Сейчас давно уже не было подобного, сп3 стоит. |
Shub-Niggurath писал(а): |
на ноуте тоже SP3 - причём лицензионный XP Home. |
