Ivan Z Форумчанин
Модем ZyXEL P660RU2 EE
Annex B работает в режиме ADSL2+
Софт: IP-TV Player v 0.27.1
Все каналы показывают нормально, но в течении 2-10 минут.
Обрывается связь и пока не перезагрузиш модем невозможно подключиться не только к IP TV но и к интернету.
У меня безлимитка (512) но физически поддерживаемая скорость на линии около 6 мб.
интернет работает стабильно. |
IVM Гуру
Параметры линии в студию. |
Ivan Z Форумчанин
В настройках модема есть "DSL Line Status" выдает вот это:
noise margin upstream: 17 db
output power downstream: 3 db
attenuation upstream: 21 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 32- 63: 00 34 55 66 77 77 88 88 88 88 87 77 76 66 54 00
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 14 db
output power upstream: 12 db
attenuation downstream: 19 db
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: 00 00 00 00 00 02 23 33 44 55 56 66 66 77 77 67
tone 96-127: 77 78 77 77 77 87 77 77 77 66 66 66 55 55 55 55
tone 128-159: 44 44 44 44 44 44 44 44 44 44 24 44 45 45 56 66
tone 160-191: 77 77 77 77 77 77 77 77 77 77 67 66 66 66 66 66
tone 192-223: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66
tone 224-255: 66 60 55 54 55 55 54 55 55 55 54 45 55 45 55 55
tone 256-287: 44 44 44 54 45 54 55 55 55 55 55 54 44 45 44 44
tone 288-319: 44 55 55 55 55 45 55 55 55 55 44 44 44 44 44 44
tone 320-351: 44 44 44 43 33 33 33 33 33 33 33 33 33 33 33 33
tone 352-383: 33 33 33 32 22 23 33 33 33 33 33 32 23 33 33 33
tone 384-415: 33 22 33 30 23 33 33 33 33 33 33 30 33 20 00 23
tone 416-447: 33 33 33 32 33 33 33 33 33 33 33 23 33 33 33 33
tone 448-479: 33 33 33 23 32 22 22 22 22 22 22 22 22 22 22 22
tone 480-511: 22 22 22 22 22 22 22 02 22 22 22 22 22 22 22 20 |
IVM Гуру
Странно. Линия хорошая, но по описанию будто модем не справляется с траффиком. Надо спросить Zyxel-водов, может, особенности какие есть в настройке, может, прошивку обновить надо. |
rendy Гуру
Ivan Z писал(а): |
Проблема имеется, attenuation upstream должно быть на порядок меньше
attenuation downstream, а здесь, как я вижу, наоборот. Необходимо проверить скрутки, правильность подключения сплиттера, состояние проводки. |
Ivan Z Форумчанин
Какой кабель для наружной проводки будет наилудшим для WS? |
Ivan Z Форумчанин
Хочу заменить линию от телефонного столба до модема, сейчас там двухжильный медный провод в однослойной пластиковой изоляции. Какой кабель выбрать для уличной проводки кто знает? |
