Разлочка Айфонов, может надо кому)
S-A
СообщениеДобавлено: Вс 8-11-09 : 08-56    Заголовок сообщения: Разлочка Айфонов, может надо кому) Ответить с цитатой
--------------3.0.1----------------
Here you can find the link to tutorial for your iphone. First you need to jailbreak it and then unlock it.
To put the latest 3.0.1 firmware on it, download it from this list - http://iclarified.com/entry/index.php?enid=750
After that use your tutorial for 3.0 firmware (it works the same), but instead of 3.0 use 3.0.1 firmware you downloaded. Then when you jailbreak it use 3.0 os (so you have to download this one as well). More info here - http://iclarified.com/entry/index.php?enid=4716
-----------Tutorials---------------------
Iphone 2g Jailbreak - \
Iphone 2g unlock - \
Iphone 3g Jailbreak - \ http://www.iclarified.com/entry/index.php?enid=2311
Iphone 3g unlock - /
Iphone 3g Jailbreak - /
Itouch 1st gen jailbreak \ Mac - http://www.iclarified.com/entry/index.php?enid=4306
Itouch 2st gen jailbreak / Windows - http://www.iclarified.com/entry/index.php?enid=4306
Just choose the one that you need!
Redsnow is torrent file -
Download it (Redsnow) from this tutorial (in the begining of step one) -
http://iclarified.com/entry/index.php?enid=4447, (it's for windows),
http://iclarified.com/entry/index.php?enid=4448 , (for mac),
and then continue to use tutorial for your iphone, thanks.
